apply a (photoshop) filter to multiple images
bluehouse68
Post by bluehouse68 »
my first post after several years using XNview :)
I got the TBFD3.8bf filter that gives good results on undersea diving images.
I can succesfully apply it manually on a per image basis (in french Xnview: filtre->Module Adobe Photoshop).
Is there a way to apply it to multiples images on same time?
In "Outil->Convertir...->Transformations", I cannot access to this kind of filter.
If not possible inside Xnview, is it possible with NConvert?
Thanks and regards,
François
Re: apply a (photoshop) filter to multiple images
bluehouse68 wrote: If not possible inside Xnview, is it possible with NConvert?
Sorry but it's not possible in batch convert
