convert PDD
Nelsa
convert PDD
Post by Nelsa »
I have a whole folder of Photoshop PDDs. I know I can fumble around and individual view the second page and save as something else. Since I have 30 of them, is there a batch procedure? If so, could you describe such so that this computer challenged old man might bumble through it? :?:
Moderator & Librarian
Re: convert PDD
Welcome, Nelsa :-)
  1. Open a PDD file in XnView.
  2. In View mode, go to the Tools menu and select Multipage file » Extract All Into....
  3. The Extract page from Multi-Page file dialog window shows up asking you for the target directory and format.
I don't have any PDD files (Adobe PhotoDeluxe), but I've done some tests with layered PSDs (Photoshop) and it worked just fine. There's no way to batch-extract pages/layers in XnView, though.
