.pdb files
Luthais
.pdb files
Post by Luthais »
I've just downloaded the XnView program and am trying to view a .pdb file but can't seem to open it and get the error message "format of the file cannot be detected". Is there something that needs to be done before I can view it? Any help would be appreciated.
marsh
Re: .pdb files
Post by marsh »
Not all pdb files contain image data. If it is a file type which needs enabling, see:
Does XnView support graphic format .xyz?
Re: .pdb files
:arrow: Luthais
:) Hello ! Welcome on board !
• There are five file-types with the *.pdb extension, coming from five different sources.
- Only the type from Palm Pilot is supported as reading and writing, the others at reading only.
- You could try also to add the extension in the File List, like shown HERE (Include).
- Ensure you too that the box is ticked in the Options at :
[Operations]
[×] Display all image file types
:mrgreen: Kind regards,
