Effects-Noise Removal
willgoss
Post by willgoss »
Effects needs a little better noise removal with slider, perhaps separate ISO noise and Color noise......and the ability to stack effects without leaving the effects menu....Also a Clarify (often accomplished with large radius Unsharp Mask) would be a nice addition to Noise ....then Sharpening slider and other sharpening methods are needed.....
Noise is very important as both a starting and finishing step consideration....currently I must use an external plugin such as Topaz Denoise of Xero Improver....
Will Goss
