It's not possible to drag and drop:
- the folders at all
- the files to folder tree and [..] item
- the files while holding Ctrl+Shift or Alt to other app or desktop to create shortcut
- the files while holding Ctrl+Shift or Alt within XnView - file is copied instead
- multiple files (probably related with another known issue)
XnViewMP Version 0.20 (Sep 25 2009), Windows Vista 32 bit SP2.
MP 0.20 Win - Drag & Drop issues
Dreamer
Re: MP 0.20 Win - Drag & Drop issues
It isn't possible too, to drag & drop folders to the favorites pane. Would be nice if this will be implemented some day
Yes I ant all these two but these are not Bugs to be reported these just features that are missing.vommie wrote:It isn't possible too, to drag & drop folders to the favorites pane. Would be nice if this will be implemented some day
Works now, except Alt+click to create shortcut, but it's not so important. Topic can be closed.
Dreamer
