[FIXED] RC1: Duplicate buttons, IPTC, ...
OL
I got duplicate menu buttons. 2 buttons at the left of "File" and 2 "_=x" buttons at the right. Couldn't find a consistent way to reproduce but it happened twice in 10 minutes.
Properties > IPTC
The first line has "????" in "name" and "Value" is either empty or like "<hellopstamp>some code</hellostamp> and copying it to clipboard leads to a reproducible crash (the memory could not be read). I would upload a sample if needed.
In version 1.74 the first line of EXIF was empty (same in this version) but the IPTC was OK
options > browser > thumbnail details
Well I'm not seeing them below my thumbnails. That's curious because a few hours ago they were displayed on about 50% of them, but now, after several restarts, none are.
Hope that helped.
Properties > IPTC
Hope that helped.
OL
Professional images are also showing the ????
For example, try any photo on http://www.sfgate.com/
It doesn't solved it, I still have this problem also with new .ini file created with RC1 (.ini sent to Pierre).Dreamer wrote:I can confirm this, I guess, removing of xnview.ini solved that problem.OL wrote:I got duplicate menu buttons. 2 buttons at the left of "File" and 2 "_=x" buttons at the right. Couldn't find a consistent way to reproduce but it happened twice in 10 minutes.
This problem is not with xnview.iniDreamer wrote:It doesn't solved it, I still have this problem also with new .ini file created with RC1 (.ini sent to Pierre).Dreamer wrote:I can confirm this, I guess, removing of xnview.ini solved that problem.OL wrote:I got duplicate menu buttons. 2 buttons at the left of "File" and 2 "_=x" buttons at the right. Couldn't find a consistent way to reproduce but it happened twice in 10 minutes.
Ok, i remove empty fields.OL wrote:Professional images are also showing the ????
I think I've seen it again in RC2. Very hard to reproduce though.I got duplicate menu buttons. 2 buttons at the left of "File" and 2 "_=x" buttons at the right. Couldn't find a consistent way to reproduce but it happened twice in 10 minutes.
Crash and empty first line has been fixed for me, okish.Properties > IPTC
OK, that "details not showing up anymore once thumbs have been cached" bug has been fixed.options > browser > thumbnail details
--> you can move my topic to Solved. If someone knows how to reproduce the duplicate menus, he'll write up another topic.
