How to print long and small pictures?
If I have a long and small picture and want to print it, I miss the possibility to distribute the picture on 2 or more pages. Up to now I can only print with one pic per page.
I can print the picture not so that I can read the text.Re: How to print long and small pictures?
I would really like (and need) the possibility to split large pictures.
Nobody else?
Nobody else?
Personally, I use large format printersn8blume wrote:...Nobody else?
Maybe you can use a "detour" with PDF? Make a large format PDF of your file and tile it with "PDF Tiler" from http://www.noliturbare.com/index.php
Peter
Hello Peter!
I didn't know the feature to save images as PDF with XnView.
Unfortunately I could not save the PNG file as PDF, I had to convert it in JPG first.
Now I can tile the PDFs also with my favorite PDF viewer "PDF XChange Viewer", free version.
PDF-Tiler changes the sides, it brings last page as first ones.
Thank you!
Heiner
Thank you!
Heiner
I didn't know it either ... - I thought "print to PDF", and this should work with PNG too ...n8blume wrote:...I didn't know the feature to save images as PDF with XnView....
But nevertheless you find a solution.
Peter
