Image size in CM
Arturas
Image size in CM
Post by Arturas »
The program shows a picture Print size in cm. Very good.
But in the table "Create Contact Sheet" is the only Image Width (inch) and Height (inch).
In the table "Print / Caption / Insert" is the only Image Width (inch) and Height (inch).
It is very necessary for the Width (cm) Height (cm).
Excuse me for my English :)
Re: Print size in CM
Hello Arturas,
did you deactivate Use inch for print size (instead of cm) in Tools » Options... » Browser » File List » Misc. » Details view?
Arturas
Post by Arturas »
by XnTriq » 09 Oct 2009, 23:15
Hello XnTriq,
Details view / Use inch for print size (instead of cm) -- This check box is not checked.
I can not get on my computer Width (cm) and Height (cm).
http://picasaweb.google.com/lh/photo/hX ... directlink
http://picasaweb.google.com/lh/photo/u_ ... directlink
Peter2
Post by Peter2 »
Arturas wrote:...But in the table "Create Contact Sheet" is the only Image Width (inch) and Height (inch). ...
There are Pixel, not Inch.
Arturas wrote:...In the table "Print / Caption / Insert" is the only Image Width (inch) and Height (inch). ...
Confirmed for german version too.
Peter
Arturas wrote:Details view / Use inch for print size (instead of cm) -- This check box is not checked.
I'd like to request that print sizes in cm be made available as variables for fullscreen info, thumbnail labels & tooltips, as well as contact sheets and web pages.
And maybe we should think about one common setting for everything?
  • Tools » Options... » Browser »
    • » Browser » Info in status bar » Print size
      » File List » Misc. » Details view » Use inch for print size (instead of cm)
Arturas
Re: Image size in CM
Post by Arturas »
I work for the newspaper stands.
My people need to know what is the image size in cm, when the image resolution is 300 dpi.
XnView screen shows image size in cm, but not printed on paper. Prints only the image size in inches.
» File List » Misc. » Details view » Use inch for print size (instead of cm) --> Does not work in Contact sheets or Print table.
XnView - The best program we use. To print on paper image size in cm, we use PageMaker or InDesign, but this is very expensive.
I do not know how well I understand what you say (a school learned the French language, but not learned, but have to communicate in English, who do not know) :shock: .
Arturas wrote:I do not know how well I understand what you say (a school learned the French language, but not learned, but have to communicate in English, who do not know) :shock: .
Google Translate: English » Lithuanian ;-)
