[OK] RC2: Minor sugg. Show full name as tooltip...
Locked
OL
Post by OL »
Note: It's my topic (just my 1st post get lost, before, not now), it's the reason why I move this topic... Another reason is at bottom.
Dreamer
there shouldn't be any tooltip if Show Tooltips is disabled, in my opinion.
ckit
Post by ckit »
He means merging two tooltips into one:
ckit wrote:He means merging two tooltips into one:
A while back I've complained about getting two tooltips. According to Pierre, the tooltip which appears for long filenames, only, is shown by Windows. Obviously there's nothing he can do about it.
Dreamer
Post by Dreamer »
No, I mean this (and only if tooltips are disabled and of course only if the name cannot be shown fully, I don't want 2 tooltips):
BTW where is my first post ??
Dreamer
Post by Dreamer »
No reply? Please see my post ("Pajero images") above. Thanks.
OL
Post by OL »
OL wrote:there shouldn't be any tooltip if Show Tooltips is disabled, in my opinion.
Why is my post at the top of the topic? there were others before.
Yes Dreamer I know that's what you meant, but in my opinion "No tooltips" means "No tooltips at all" and not "No tooltips except for filenames, when I'm too lazy to adjust column width" ;)
Or perhaps there could be an option a bit like this (taken from my audio player):
Danny
Post by Danny »
Those aren't even tooltips. Tooltips explain something like the function of a button. I don't mind the "No tooltips except for filenames, when I'm too lazy to adjust column width"-solution.
OL
Post by OL »
I'm not against an option to show filename tooltips when filenames are clipped, my point was that if you choose *no* tooltips then there should be *no* tooltips, duh :p
Well that's not so important to me anyhow.
As written above, the native Windows controls used by Pierre automatically show tooltips if file names are truncated. According to Pierre there is no way to work around this. This is why there can be double tooltipps or tooltipps although they have been switched off.
(The tooltipp with image format and image details is Pierre's tooltip, the one with the full filename is MS Windows).
Dreamer
Post by Dreamer »
helmut wrote:According to Pierre there is no way to work around this. This is why there can be double tooltipps or tooltipps although they have been switched off.
Sorry I misunderstood, so "my way" is not possible?
And what about these options:
- Never show any tooltips (as now with "Show tooltips" disabled)
- Always show full tooltips (as now with "Show tooltips" enabled)
and - Show "name" tooltips only if the name cannot be shown fully (as below)
If it's not possible, just say, it's not possible, thanks.
Dreamer wrote:If it's not possible, just say, it's not possible, thanks.
It's not possible.
OL
Post by OL »
helmut wrote:As written above, the native Windows controls used by Pierre automatically show tooltips if file names are truncated. According to Pierre there is no way to work around this. This is why there can be double tooltipps or tooltipps although they have been switched off.
I may be misunderstanding you, but I've set Show Tooltips to off and *both* tooltips are off (which is okay for me)
Dreamer
Post by Dreamer »
It's not possible.
OK so moved to "Solved Bugs, Requests, and Suggestions".
Locked
