Problem getting change timestamp to work
Doug
Post by Doug »
What is the trick to get the change timestamp option in the tools menu to work? I have a directory of pictures and I need to change the time stamp from PM to AM. I do a -12:00 and the dates look correct on the screen, I click apply and it looks like it is working, but then I go and look at the picture and the date is not changed. What am I doing wrong? I also tried it in the EXIF tab with the same results. Your assistance is appreciated.
Doug
Re: Problem getting change timestamp to work
I have no problem. You would like to change the EXIF date taken? Which result do you have?
Doug
Post by Doug »
Yes, I would like to change the EIFX date taken. I change it with the timestamp change option and choose apply. then I go and look at the picture and the date has not changed. Is there a special way to save it or make the file change?
Could you send me a sample?
Hilmar
Post by Hilmar »
I have a similar problem:
I want to change the File Dates 'created' and 'modified' by using the Exif Date 'taken'.
Applying this in Tools-->Change Timestamp shows no effect.
XnView Version 1.96.5, 1.97 Beta 3 and Win7 x64, WinXP Pro SP3
Please see attached picture.
Hilmar
I have no problem, could you send me a jpeg sample?
Hilmar
Post by Hilmar »
Mea culpa!
I just realized it too: it was a read-only file - of course nothing could be changed.
Sorry for the inconvenience
Hilmar
