.MIX Files bug
Chem33
.MIX Files bug
Post by Chem33 »
Hello. Thanks for the great program. It has served its purpose a lot of times for me.
However I came across to a (maybe) bug. I need to convert quite a few .mix images. But when I open them with the latest stable release of XnView, it detects them as Picture It! thumbnail and it does not detect the pictures correct size. Here is a .mix file to reproduce the problem.
http://www.mediafire.com/?yzan1njwfgr
Thanks in advance!
Re: .MIX Files bug
XnView can only extract thumbnail from MIX files
Chem33
Re: .MIX Files bug
Post by Chem33 »
So it's not a bug... Too bad, I was hoping it would be a bug because I now have to convert one by one every .mix image I have with Microsoft Picture It!. :(
There is no way for XnView to manipulate .mix images correctly?
Thanks for your quick reply.
