How to make NConvert *NOT* automatically overwrite files?
ArtyTheRat
Post by ArtyTheRat »
This program is excellent in so many ways, but there is one very important thing I can't understand: I see it overwrites files with no warnings or anything. This is a very troublesome problem for me. What is the switch that forces it to not overwrite files?
I see another user has asked this question, but I didn't really see the response.
Thank you for this great tool.
Arty
DOS386
Re: How to make NConvert *NOT* automatically overwrite files?
Post by DOS386 »
Here: http://newsgroup.xnview.com/viewtopic.php?f=57&t=15834 ???
Because there is none ?
I still think the same way as > 1 year ago: default should be DON'T WRITE into EXISTING FILES , and maybe add a switch "do write into existing files" Image
DOS386 wrote:... I still think the same way as > 1 year ago: default should be DON'T WRITE into EXISTING FILES , and maybe add a switch "do write into existing files"
+1 Default should really be "Do not overwrite existing files"
