Error by sorting via EXIF-Date!
fidelcastro54
Post by fidelcastro54 »
Hi Guys!
First, sorry for my bad English! Now my Problem! If i sort my Pictures via EXIF-Date, XN-View uses the build Date of the File! In the proberties of the Files, the EXIF date seems to be correct (e.g. File-Date 11.01.2010 -> EXIF-Date 10.01.2010, but sorted wrong)! I don't know what it is, this Error is permanently in all of my Photo Directories! Is it an Bug or is it my fault? Please give me an answer!
Thx
Marcus
Re: Error by sorting via EXIF-Date!
The EXIF date taken is good? sort use it
fidelcastro54
Yes the Date is good! If i use the tool "Date and Time Change" and Change the "build Time" and "last change Time" the Files are sorted correct via the EXIF-Date! In File-proberties the EXIF-Date is shown correct!
fidelcastro54 wrote: In File-proberties the EXIF-Date is shown correct!
Which exif date? Taken or modified?
fidelcastro54
All dates! If ilokk into the proberties there are 3 Dates (I think, sorry i'm at work) and all the Dates are for e.g. 2010-01-10 15:43 and the creation date is 11.01.2010 18:40! After i use the tool and change all 5 dates the sort is correct!
Could you send me 2 or 3 files to check?
fidelcastro54
Sorry I changed all the Files manually! If i get some new Pics i'll send it to you!
