Paint not available in menu "Filter"
buthead
Post by buthead »
how do i install paint plugin? no instructions in downloaded paint plugin archive, cant find instructions anywhere1
DO I JUST extract and copy files to XnView's Filters dir?
Re: Use of paint plugin.
buthead wrote:how do i install paint plugin? no instructions in downloaded paint plugin archive, cant find instructions anywhere1
XnView's Paint tool is an AddOn and must be downloaded and unpacked in the AddOn folder. Please see following topics for download and more background info:
- 'Addons/Plugins/...' (AddOn "Basic paint features (text, line, rectangle, watermark, ...) in view mode)
- Let's talk about Plug-Ins
buthead
Post by buthead »
Ok... I have compleatly re-read all of the suggested info IE "lets talk plugins" ect.ect.
Just to make sure I got it right,I coppied the two files from the paint archive i downloaded to... the plugins folder,the addon folder,the filter folder,and just for good measure, even to the 8bf folder. Then Open up a picture, click on the "filter" button, and still i see nothing refering to any paint tool! am i missing something here? after opening a picture am i not in "view" mode? if not how do i get into "view" mode? I really love this program, and have used it for years. It sure would be handy to have some basic draw tools!
Thanks for you're time... John
PS. Does the paint addon work in older versions of XnView?
Mabye this is the problem? I am using file version:1.90.00 and product version 1.90.2
Re: Paint Plugin not available
xnview in [url=http://newsgroup.xnview.com/viewtopic.php?f=35&t=12213]Paint plugin v1.0[/url] wrote: Please note that the Paint plug-in works with the latest version of XnView (1.90.3), only.
You will need XnView 1.90.3 or later.
