PDF thumbnail not working in Windows 7 64x with Ghostscript
hing_hong
Post by hing_hong »
Hi
Is anyone able to help? Love XnView, but I really need my PDFs to show a thumbnail. Only the icon is showing :(
I've tried the 32-bit and 64-bit version of Ghostscript but no luck :(
hing_hong
Re: PDF thumbnail not working in Windows 7 64x with Ghostscript
Post by hing_hong »
This sux
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=49955#p49955]“AFPL ghostscript was not found on your system”[/url]) wrote:
jwalker46 wrote:
xnview wrote:Is it gs856w64.exe or gs856w32.exe??
64
Ok!!! So it's normal, xnview is 32bits so can't use 64bits dll
mairondil
Post by mairondil »
hing_hong wrote:Hi
From http://www.prepressure.com/library/file-formats/eps:
For other file formats such as JPG or PNG, Explorer shows a thumbnail of the actual image content. This can be very practical when dealing with large amounts of files. There is a little tool called PS+Ai Thumb which at least partly solves this problem. It works on some images but not on all types of EPS files, as shown below. I’ve only used it with Windows XP. It does not work on the 64-bit version of Windows 7.
