Dstruct
Posts: 233 Joined: Fri May 02, 2008 9:27 am
Post
by Dstruct » Thu Jan 28, 2010 11:05 am
XnView 1.97 + ffdshow tryouts rev3222
-> set xnview.exe to the list in "Don't use ffdshow in" in ffdshow preferences (direct show control)
-> open AVI file (DivX 5 in my case) in xnview
-> exit xnview
-> open taskmanager
=> xnview.exe still running
Doing this several times gives you many many running/hanging xnview.exe processes!
Allowing xnview to use ffdshow doesn't give this problem!
Not sure if this is a ffdshow or xnview bug ...
https://sourceforge.net/tracker/?func=d ... tid=867360
Posts: 47518 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Fri Jan 29, 2010 2:39 pm
Strange i use ffmpeg too, and xnview quits correctly...
Dstruct
Post
by Dstruct » Fri Jan 29, 2010 2:51 pm
xnview wrote: Strange i use ffmpeg too, and xnview quits correctly...
you mean ffdshow right? which version?
maybe you can try my settings too: ffdshow.reg ?
here my xnview settings: xnview.ini
ffdshow is the only codec on my windows xp sp3. no other 3rd party codecs or splitters installed!
strange is that ffdshow obviously still is in use when opening an avi (DivX 5 at least) in xnview (even with xnview.exe on the ffdshow blacklist)!?
Post
by xnview » Sun Jan 31, 2010 4:12 pm
Could you send me an avi with the problem?
Dstruct
Post
by Dstruct » Sun Jan 31, 2010 6:37 pm
xnview wrote: Could you send me an avi with the problem?
Sure, here you go: xnview.rar (8.38 MB)
MediaInfo says this:
General
Complete name : D:\xnview.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 8.65 MiB
Duration : 2mn 34s
Overall bit rate : 470 Kbps
Writing library : VirtualDub build 32794/release
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 2mn 34s
Bit rate : 330 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.057
Stream size : 6.06 MiB (70%)
Writing library : Lavc51.51.0
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format_Settings_Mode : Joint stereo
Format_Settings_ModeExtension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2mn 34s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 2.35 MiB (27%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 522 ms
Post
by xnview » Tue Feb 02, 2010 2:57 pm
I can't reproduce the problem....
Which codec is used if you don't use the one in ffdshow??
Dstruct
Post
by Dstruct » Tue Feb 02, 2010 3:14 pm
xnview wrote: I can't reproduce the problem....
Good question. So I've tried Windows Media Player 11 (blacklisted in ffdshow) -> crash in quartz.dll (this is the DivX decoder in Windows XP I think). Obviously that's the reason of XnView hanging I guess!? Did you try this on Windows XP SP3 with Media Player 11 (and all latest Windows Updates)?
Microsoft (R) DrWtsn32
Copyright (C) 1985-2001 Microsoft Corp. Alle Rechte vorbehalten.
Anwendungsausnahme aufgetreten:
Anwendung: C:\Programme\Windows Media Player\wmplayer.exe (pid=1752)
Wann: 02.02.2010 @ 16:11:25.234
Ausnahmenummer: c0000005 (Zugriffsverletzung)
*----> Systeminformationen <----*
Terminalsitzungskennung: 0
Prozessoranzahl: 2
Prozessortyp: x86 Family 6 Model 15 Stepping 6
Windows-Version: 5.1
Aktuelles Build: 2600
Service Pack: 3
Aktueller Typ: Multiprocessor Free
*----> Taskliste <----*
0 System Process
4 System
316 smss.exe
372 csrss.exe
396 winlogon.exe
440 services.exe
452 lsass.exe
612 svchost.exe
680 svchost.exe
736 svchost.exe
804 spoolsv.exe
1108 Explorer.EXE
1252 hdsp32.exe
1276 hdspmix.exe
1776 emule.exe
524 svchost.exe
1656 totalcmd.exe
1896 firefox.exe
1068 uTorrent.exe
1116 taskmgr.exe
1300 svchost.exe
1752 wmplayer.exe
1528 drwtsn32.exe
*----> Modulliste <----*
(0000000000b00000 - 0000000000dd9000: C:\WINDOWS\system32\xpsp2res.dll
(0000000001000000 - 0000000001013000: C:\Programme\Windows Media Player\wmplayer.exe
(0000000001560000 - 0000000001569000: C:\WINDOWS\system32\Normaliz.dll
(0000000001c60000 - 0000000001c89000: C:\WINDOWS\system32\msls31.dll
(00000000026e0000 - 00000000026fa000: C:\WINDOWS\system32\ff_vfw.dll
(0000000003f40000 - 0000000003f72000: C:\WINDOWS\system32\upnphost.dll
(0000000007940000 - 000000000797b000: C:\WINDOWS\system32\cewmdm.dll
(000000000bef0000 - 000000000bf27000: C:\WINDOWS\system32\MFPlat.DLL
(000000000dfb0000 - 000000000dfe9000: C:\WINDOWS\system32\MsPMSP.dll
(000000000e510000 - 000000000e562000: C:\WINDOWS\system32\MSWMDM.dll
(0000000010000000 - 0000000010440000: C:\Programme\Ffdshow\ffdshow.ax
(0000000011c70000 - 0000000011caa000: C:\WINDOWS\system32\WMASF.DLL
(0000000011d10000 - 0000000011d1d000: C:\WINDOWS\system32\WMDMPS.dll
(0000000012950000 - 00000000133b6000: C:\WINDOWS\system32\wmp.dll
(00000000134d0000 - 000000001351c000: C:\WINDOWS\system32\wmpeffects.dll
(0000000013740000 - 0000000013f27000: C:\WINDOWS\system32\wmploc.dll
(0000000014030000 - 0000000014054000: C:\WINDOWS\system32\wmpps.dll
(0000000015110000 - 000000001536c000: C:\WINDOWS\system32\WMVCore.DLL
(00000000407f0000 - 00000000408a4000: C:\WINDOWS\system32\jscript.dll
(00000000408b0000 - 0000000040996000: C:\WINDOWS\system32\WININET.dll
(00000000409a0000 - 0000000040f4e000: C:\WINDOWS\system32\mshtml.dll
(0000000040f50000 - 0000000041138000: C:\WINDOWS\system32\iertutil.dll
(0000000041140000 - 0000000041bd3000: C:\WINDOWS\system32\ieframe.dll
(00000000452e0000 - 0000000045412000: C:\WINDOWS\system32\urlmon.dll
(000000004d5c0000 - 000000004d619000: C:\WINDOWS\system32\WINHTTP.dll
(000000004eba0000 - 000000004ed4b000: C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4c2df\gdiplus.dll
(000000004fd50000 - 000000004fef6000: C:\WINDOWS\system32\d3d9.dll
(00000000597d0000 - 0000000059825000: C:\WINDOWS\system32\NETAPI32.dll
(0000000059dd0000 - 0000000059e71000: C:\WINDOWS\system32\dbghelp.dll
(000000005b0f0000 - 000000005b128000: C:\WINDOWS\system32\UxTheme.dll
(000000005cf00000 - 000000005cf26000: C:\WINDOWS\system32\ShimEng.dll
(0000000068000000 - 0000000068036000: C:\WINDOWS\system32\rsaenh.dll
(000000006de80000 - 000000006de86000: C:\WINDOWS\system32\d3d8thk.dll
(000000006f8c0000 - 000000006f96b000: C:\Programme\Ffdshow\libmplayer.dll
(000000006fac0000 - 0000000070319000: C:\Programme\Ffdshow\libavcodec.dll
(00000000715e0000 - 0000000071659000: C:\WINDOWS\AppPatch\AcLayers.DLL
(0000000071a00000 - 0000000071a08000: C:\WINDOWS\system32\WS2HELP.dll
(0000000071a10000 - 0000000071a27000: C:\WINDOWS\system32\WS2_32.dll
(0000000071b70000 - 0000000071b83000: C:\WINDOWS\system32\SAMLIB.dll
(0000000072210000 - 000000007223b000: C:\WINDOWS\system32\DINPUT.dll
(0000000072c40000 - 0000000072c58000: C:\WINDOWS\system32\l3codecx.ax
(0000000072c80000 - 0000000072c88000: C:\WINDOWS\system32\msacm32.drv
(0000000072c90000 - 0000000072c99000: C:\WINDOWS\system32\wdmaud.drv
(0000000072f70000 - 0000000072f96000: C:\WINDOWS\system32\WINSPOOL.DRV
(00000000735f0000 - 00000000735f8000: C:\WINDOWS\system32\msyuv.dll
(0000000073620000 - 0000000073627000: C:\WINDOWS\system32\msdmo.dll
(00000000736d0000 - 000000007371b000: C:\WINDOWS\system32\DDRAW.dll
(00000000738b0000 - 0000000073980000: C:\WINDOWS\system32\D3DIM700.DLL
(0000000073b30000 - 0000000073b36000: C:\WINDOWS\system32\DCIMAN32.dll
(0000000073e40000 - 0000000073e44000: C:\WINDOWS\system32\KsUser.dll
(0000000073e70000 - 0000000073ecc000: C:\WINDOWS\system32\DSOUND.DLL
(0000000074790000 - 00000000748fe000: C:\WINDOWS\system32\quartz.dll
(0000000074e80000 - 0000000074e8c000: C:\WINDOWS\system32\SSDPAPI.dll
(0000000075250000 - 000000007527e000: C:\WINDOWS\system32\msctfime.ime
(0000000075dc0000 - 0000000075e51000: C:\WINDOWS\system32\mlang.dll
(0000000075ec0000 - 0000000075ee1000: C:\WINDOWS\system32\MSVFW32.dll
(0000000076320000 - 0000000076325000: C:\WINDOWS\system32\MSIMG32.dll
(0000000076330000 - 000000007634d000: C:\WINDOWS\system32\IMM32.DLL
(0000000076350000 - 000000007639a000: C:\WINDOWS\system32\COMDLG32.dll
(00000000765f0000 - 0000000076601000: C:\WINDOWS\system32\devenum.dll
(0000000076620000 - 00000000766d6000: C:\WINDOWS\system32\USERENV.dll
(0000000076740000 - 000000007674c000: C:\WINDOWS\system32\cryptdll.dll
(0000000076970000 - 0000000076a21000: C:\WINDOWS\system32\SXS.DLL
(0000000076af0000 - 0000000076b1e000: C:\WINDOWS\system32\WINMM.dll
(0000000076bb0000 - 0000000076bbb000: C:\WINDOWS\system32\PSAPI.DLL
(0000000076bf0000 - 0000000076c1e000: C:\WINDOWS\system32\WINTRUST.dll
(0000000076c50000 - 0000000076c78000: C:\WINDOWS\system32\IMAGEHLP.dll
(0000000076d20000 - 0000000076d39000: C:\WINDOWS\system32\iphlpapi.dll
(0000000076e40000 - 0000000076e4e000: C:\WINDOWS\system32\rtutils.dll
(0000000076e50000 - 0000000076e62000: C:\WINDOWS\system32\rasman.dll
(0000000076e70000 - 0000000076e9f000: C:\WINDOWS\system32\TAPI32.dll
(0000000076ea0000 - 0000000076edc000: C:\WINDOWS\system32\RASAPI32.dll
(0000000076f20000 - 0000000076f4d000: C:\WINDOWS\system32\WLDAP32.dll
(0000000076f90000 - 000000007700f000: C:\WINDOWS\system32\CLBCATQ.DLL
(0000000077010000 - 00000000770e3000: C:\WINDOWS\system32\COMRes.dll
(00000000770f0000 - 000000007717b000: C:\WINDOWS\system32\OLEAUT32.dll
(00000000773a0000 - 00000000774a3000: C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
(00000000774b0000 - 00000000775ed000: C:\WINDOWS\system32\ole32.dll
(0000000077660000 - 0000000077681000: C:\WINDOWS\system32\NTMARTA.DLL
(00000000778f0000 - 00000000779e4000: C:\WINDOWS\system32\SETUPAPI.dll
(0000000077a50000 - 0000000077ae6000: C:\WINDOWS\system32\CRYPT32.dll
(0000000077af0000 - 0000000077b02000: C:\WINDOWS\system32\MSASN1.dll
(0000000077b10000 - 0000000077b32000: C:\WINDOWS\system32\appHelp.dll
(0000000077ba0000 - 0000000077ba7000: C:\WINDOWS\system32\midimap.dll
(0000000077bb0000 - 0000000077bc5000: C:\WINDOWS\system32\MSACM32.dll
(0000000077bd0000 - 0000000077bd8000: C:\WINDOWS\system32\VERSION.dll
(0000000077be0000 - 0000000077c38000: C:\WINDOWS\system32\msvcrt.dll
(0000000077c40000 - 0000000077c65000: C:\WINDOWS\system32\msv1_0.dll
(0000000077da0000 - 0000000077e4a000: C:\WINDOWS\system32\ADVAPI32.dll
(0000000077e50000 - 0000000077ee2000: C:\WINDOWS\system32\RPCRT4.dll
(0000000077ef0000 - 0000000077f39000: C:\WINDOWS\system32\GDI32.dll
(0000000077f40000 - 0000000077fb6000: C:\WINDOWS\system32\SHLWAPI.dll
(0000000077fc0000 - 0000000077fd1000: C:\WINDOWS\system32\Secur32.dll
(000000007c800000 - 000000007c908000: C:\WINDOWS\system32\kernel32.dll
(000000007c910000 - 000000007c9c9000: C:\WINDOWS\system32\ntdll.dll
(000000007e360000 - 000000007e3f1000: C:\WINDOWS\system32\USER32.dll
(000000007e670000 - 000000007ee91000: C:\WINDOWS\system32\SHELL32.dll
*----> Statusabbild für Threadkennung 0x55c <----*
eax=00000000 ebx=00000010 ecx=00000080 edx=02e5d002 esi=02b27a2a edi=00000000
eip=7483eef4 esp=026de4fc ebp=026de51c iopl=0 nv up ei pl nz na pe nc
cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00000202
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\WINDOWS\system32\quartz.dll -
Funktion: quartz
7483eed5 c1fa08 sar edx,0x8
7483eed8 03d1 add edx,ecx
7483eeda 8955ec mov [ebp-0x14],edx
7483eedd 0fb65602 movzx edx,byte ptr [esi+0x2]
7483eee1 895510 mov [ebp+0x10],edx
7483eee4 0fb65603 movzx edx,byte ptr [esi+0x3]
7483eee8 895508 mov [ebp+0x8],edx
7483eeeb 8b5518 mov edx,[ebp+0x18]
7483eeee c1fb08 sar ebx,0x8
7483eef1 83c310 add ebx,0x10
FEHLER ->7483eef4 885afe mov [edx-0x2],bl ds:0023:02e5d000=??
7483eef7 8b5510 mov edx,[ebp+0x10]
7483eefa 8b5d08 mov ebx,[ebp+0x8]
7483eefd 6bd270 imul edx,edx,0x70
7483ef00 6bdb4a imul ebx,ebx,0x4a
7483ef03 2bd3 sub edx,ebx
7483ef05 03c1 add eax,ecx
7483ef07 8bdf mov ebx,edi
7483ef09 c1f808 sar eax,0x8
7483ef0c 6bdb26 imul ebx,ebx,0x26
7483ef0f 03c1 add eax,ecx
*----> Stack Back Trace <----*
WARNING: Stack unwind information not available. Following frames may be wrong.
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\WINDOWS\system32\kernel32.dll -
ChildEBP RetAddr Args to Child
026de51c 7482642b 00000000 00000400 00000000 quartz+0xaeef4
026de678 74826c8d 01d4d5e0 01d4d700 00000000 quartz+0x9642b
026df6d4 74828486 00f6a6b0 00000000 00000000 quartz+0x96c8d
026df8e8 74826663 00f6a6b0 00000000 01d4d640 quartz+0x98486
026dfd14 74827d6f 01d4d640 00000000 00000000 quartz+0x96663
026dffac 74825ce6 026dffec 7c80b729 00f6a4c0 quartz+0x97d6f
026dffb4 7c80b729 00f6a4c0 00000020 00000000 quartz+0x95ce6
026dffec 00000000 74825cd9 00f6a4c0 00000000 kernel32!GetModuleFileNameA+0x1ba
*----> Raw Stack Dump <----*
00000000026de4fc 28 00 9c 02 00 04 00 00 - 00 10 00 00 80 00 00 00 (...............
00000000026de50c 99 00 00 00 02 cb e5 02 - 2a 70 b2 02 c0 00 00 00 ........*p......
00000000026de51c 78 e6 6d 02 2b 64 82 74 - 00 00 00 00 00 04 00 00 x.m.+d.t........
00000000026de52c 00 00 00 00 00 10 00 00 - 02 d0 e5 02 00 05 00 00 ................
00000000026de53c 28 f9 6d 02 01 00 00 00 - b0 a6 f6 00 7c 00 00 00 (.m.........|...
00000000026de54c 0f 10 00 00 68 01 00 00 - 80 02 00 00 00 05 00 00 ....h...........
00000000026de55c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00000000026de56c 00 c8 de 02 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00000000026de57c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00000000026de58c 00 00 00 00 20 00 00 00 - 04 00 00 00 59 55 59 32 .... .......YUY2
00000000026de59c 10 00 00 00 ff 00 ff 00 - 00 ff 00 00 00 00 00 ff ................
00000000026de5ac 00 00 00 00 40 40 10 10 - 00 00 00 00 00 00 00 00 ....@@..........
00000000026de5bc 00 00 00 00 00 00 00 00 - 7c 00 00 00 0f 10 00 00 ........|.......
00000000026de5cc 00 02 00 00 00 04 00 00 - 00 10 00 00 00 00 00 00 ................
00000000026de5dc 00 00 00 00 00 00 00 00 - 00 00 00 00 28 00 9c 02 ............(...
00000000026de5ec 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00000000026de5fc 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00000000026de60c 20 00 00 00 40 00 00 00 - 00 00 00 00 20 00 00 00 ...@....... ...
00000000026de61c 00 00 ff 00 00 ff 00 00 - ff 00 00 00 00 00 00 00 ................
00000000026de62c 40 08 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 @...............
*----> Symboltabelle <----*
747b365c quartz!DllGetClassObject
747c8cee quartz!DllCanUnloadNow
747e80cf quartz!DllUnregisterServer
747e81fc quartz!DllRegisterServer
747eb64b quartz!GetProxyDllInfo
747eb8a3 quartz!DBToAmpFactor
747eb8d6 quartz!AmpFactorToDB
747eb916 quartz!AMGetErrorTextW
747eb994 quartz!AMGetErrorTextA
Post
by xnview » Wed Feb 03, 2010 9:00 pm
No i have only MediaPlayer9...
Post
by xnview » Thu Feb 04, 2010 8:16 am
I've tried on a clean XP SP3 + WM11 + all fix, and i don't have crash. WM11 can't play the file.
Perhaps you have installed another codec??
You can try GSpot or AVIcodec (
http://avicodec.free.fr/ftp/AVIcodec_1.2_b106.exe ) on your mp4
Dstruct
Post
by Dstruct » Thu Feb 04, 2010 12:58 pm
xnview wrote: I've tried on a clean XP SP3 + WM11 + all fix, and i don't have crash. WM11 can't play the file.
No. But I just found the reason of the crash in WMP11:
I had "Qualitymode" enabled in it (instead of "Overlay").
See
http://www.onlinehowto.net/tuts_pic/400 ... verlay.jpg
So with the default overlay mode it doesn't crash anymore. But: The "XnView.exe remaining in taskmanager" problem isn't gone. Same as before
Post
by xnview » Thu Feb 04, 2010 3:03 pm
Dstruct wrote: So with the default overlay mode it doesn't crash anymore. But: The "XnView.exe remaining in taskmanager" problem isn't gone. Same as before
But if you have a codec. On my clean XP, the avi can't be opened by XnView...
Dstruct
Post
by Dstruct » Thu Feb 04, 2010 3:36 pm
These are the codecs I have: codecs.png
You see, besides ffdshow there are only LAME and AC3 ACM codecs. And I've changed the integrated l3codeca.acm into l3codecp.acm (Professional Fraunhofer MP3 encoder). But these shouldn't be related to this issue at all.
And I have Media Player Classic Homecinema 1.3.1249.0 installed too. Don't know if that one installs some splitters/codecs ...
When playing that AVi in WMP11 without ffdshow I can't see which codec is in use:
Properties:
Audiocodec: MPEG Layer-3 Decoder
Videocodec: -
Post
by xnview » Thu Feb 04, 2010 4:14 pm
Dstruct wrote: When playing that AVi in WMP11 without ffdshow I can't see which codec is in use:
You have video? I have only audio...
Dstruct
Post
by Dstruct » Thu Feb 04, 2010 4:50 pm
xnview wrote: Dstruct wrote: When playing that AVi in WMP11 without ffdshow I can't see which codec is in use:
Yeah, I have video too. But you're right, obviously it shouldn't:
http://www.hardwaregeeks.com/board/show ... hp?t=29539
What version number is your WMP11? Mine is 11.0.5721.5268!
Also that quartz.dll crash I had refers to DirectX in some way I think. I have that Microsoft DirectX End-User Runtimes (August 2009) installed here too.
http://www.microsoft.com/downloads/deta ... laylang=en
Also, could you add support in XnView to view the used filter(s) - in the contextmenu for example?
Dstruct
Post
by Dstruct » Thu Feb 04, 2010 5:05 pm
Here a list of available external filters in Media Player Classic - Homecinema: mpc-hc-filter.png
