Transparency checker board color
poppy5
Post by poppy5 »
hi,
i know it's small but working with lots of PNG files and transparent borders it would be nice to be able to change the colors/size of the transparency checker board (alpha channel), similar to the option in PS preference. thus, you have more contrast in transparent areas.
sth like this:
thx :mrgreen:
Re: Transparency checker board color
You can change in the .ini CheckerColor1 & CheckerColor2
:arrow: XnView Tweak UI
ckv ([url=http://newsgroup.xnview.com/viewtopic.php?p=73420&hilit=checkercolor1+checkercolor2+checkersize#p73420]UI-less Settings[/url]) wrote:View:
  • CheckerColor1:
    Changes the first colour of the checkerboard pattern background.
    Value: Raw colour (integer) or fromated colour string
    CheckerColor2:
    Changes the second colour of the checkerboard pattern background.
    CheckerSize:
    Changes the size of squares in the checkerboard pattern background.
    Value: Integer, default value is 8
