Batch extract of Icons from ICO
Peter2
Post by Peter2 »
Is it possible to extract per Batch all Icons (all Frames) from 150 ICO-Files?
Regards
Peter
Re: Batch extract of Icons from ICO
  1. Greenfish Icon Editor Pro for creating an icon library (ICL) of all 150 icons
  2. LionTech ResThief for extracting all “frames” of all icons in the ICL in one go via drag & drop
Peter2 wrote:Is it possible to extract per Batch all Icons (all Frames) from 150 ICO-Files?
Multipage/Extract all?
Peter2
Post by Peter2 »
xnview wrote:Multipage/Extract all?
Yes, for one file.
But 150 files in batch Mode?
Peter
Yes, for one file.
it's a problem... there is no batch command for that
You can use NConvert
Peter2
Post by Peter2 »
xnview wrote:...You can use NConvert
This could be the right way. Thanks.
Peter
Please post the syntax once you've found out how this can be done with nconvert, Peter.
I'd also be interested to learn what the answer to this question is, BTW.
nconvert -xall -out png file.ico
Peter2
Post by Peter2 »
xnview wrote:nconvert -xall -out png file.ico
Thanks Pierre.
Peter
Guidance ([url=http://newsgroup.xnview.com/viewtopic.php?p=706#p706]Icon Library Batch Save[/url]) wrote:He asked how to save all these icons displayed in the screen to files!!
Aha, I got it:
nconvert -o d:\tmp\ico\%.ico -out ico -xall D:\tmp\icl\*.icl
Thanks, nconvert !
:D
