Files are not copyable by drag & drop inside File Browser?
pstein
Post by pstein »
The situation is as follows in XnView: On the left side the directory tree pane is visible while on the right the current directory with all the picture thumbnails is shown.
I can do now a MOVE by drag & drop. That means I can press the left mouse on a thumbnail and drag the picture to another directory in the tree on the left. Fine.
What I can NOT do is a COPY drag & drop. Similar to standard Windows Explorer I expected a mouse right click on a thumbnail and drag it to a directory in the tree pane on the left. Then relase the mouse button and a menu/dialog prompt pop up what to do with the picture: copy or move.
Do I have to enabel this feature somewhere?
Or is this not implemented?
Peter
pstein
Re: Files are not copyable by drag & drop inside File Browse
Post by pstein »
....no answer?
It's not implemented
