jpeg saved to black and white has a bigger file size??!!
snorkyller
Post by snorkyller »
Could you explain me this? :
I opened an jpeg image, did not make any change, just saved it to jpeg 50% quality. Result: 151ko
Then, I opened the same image, converted it to binary (no dither), and saved it to jpeg 50% quality. Result: 204Ko
I thought I would decrease the image size by reducing the number of colors.
Re: jpeg saved to black and white has a bigger file size??!!
snorkyller wrote:I thought I would decrease the image size by reducing the number of colors.
JPEG can't save black&white picture so the picture is converted in greyscale
oops66
Post by oops66 »
Maybe you can use a pluggin like: Ximagic GrayDither toolbox
http://newsgroup.xnview.com/viewtopic.php?f=38&t=16977
http://www.ximagic.com/
foxyshadis
Post by foxyshadis »
snorkyller wrote:Could you explain me this? :
That only works for lossless formats - bmp, png, gif, etc. All it does for jpeg is screw it up completely. Never reduce colors or dither a jpeg - or save it as another format if you need to.
