[Fixed?] RC2: Shift + Left/Right Arrow Won't Multi-Select
Locked
OL
Post by OL »
^ as subject says. It'll move selection instead. shift+up or down arrow work though.
Applies to Thumbnails and Icons modes (List is okay).
marsh
Post by marsh »
It can work with icons only if you press <shift + down arrow> first.
Danny
Post by Danny »
I can confirm this.
ckit
Post by ckit »
I think it's only suppose to work in List mode, all others are Shift+Down or Up.
OL
Post by OL »
Note: press shift+down, then don't release shift and press right -> it works
Re: RC2: Shift + Left/Right Arrow Won't Multi-Select
OL wrote:^ as subject says. It'll move selection instead. shift+up or down arrow work though.
Ok, i'll fix it
Olive
Post by Olive »
It's fixed, thanks Pierre.
Locked
