Opening Multiple Image Attachments in MS Outlook
Lampfishes
Post by Lampfishes »
Hi all. Can anyone tell me how to force XnView not to open a new instance for each mail attachment when viewing with XnView? It would be nifty if there was a view all attachments option or a setting to reuse the current instance. Cheers
mrwul
Re: Opening Multiple Image Attachments in MS Outlook
Post by mrwul »
Getting back on this 'old thread'
No.. I donot have the answer :(
and Yes, me-too I would like that as well.
am afraid though Outlook does not allow 3rd pary applications to access the contents or so, just old fashioned way
save attachments and then use Explorer or something to launch them. Bad luck.
