I´ve saved my avatar as a PNG with GIMP 2.6.7. As you might see, the transparency is shown correctly in the browser (Opera for me), but when I open that file in XnView 1.97.4 is has a white background.
I tried checking "Use checkerboard pattern as background" in "Options > View > View", but that didn´t change it.
How do I get to "see" the transparency?
Lars
Transparency in PNGs is shown as white
Re: Transparency in PNGs is shown as white
Do you have disabled option/Read-write/Read/PNG>compose alpha,
larsen
No, both options are checked.
Please uncheck themlarsen wrote:No, both options are checked.
larsen
It is ok when I uncheck "Compose image with alpha (32bits)". The other does not seem to matter.
