[Fixed?] RC2: Thumbnails aren't rotated according to Exif or
Locked
OL
Post by OL »
If you check options>read>rotate images based on Exif orientation, browser thumbnails won't be refreshed (ie rotated) until you delete them from cache then add them again.
Re: RC2: Thumbnails aren't rotated according to Exif orienta
OL wrote:If you check options>read>rotate images based on Exif orientation, browser thumbnails won't be refreshed (ie rotated) until you delete them from cache then add them again.
Ok, i'll fix it
Olive
Post by Olive »
Thanks Pierre
Olive
Post by Olive »
Fixed in RC3, though you need to browse to another folder then back to see the changes (clicking the Refresh toolbar button does nothing about orientation)
Locked
