Hey Guys,
I need a little help here.
I have XNView configured perfectly on one computer. All the tweaks and settings done to make me happy on my laptop. The problem is that I have having a heck of time trying to replicate the same configuration on my desktop.
I wanted to know if XNView has a setup or configuration file that can be exported from one XNVIew to another?
This would make life so much easier.
Any advice on how to transfer settings between XNView would ge greatly appreciated.
- Ton
Exportable XNView CFG / INI File?
- Forum Librarian
Re: Exportable XNView CFG / INI File?
FAQ: Info about XnView's settings (store & load)
- xnwiew.ini (Info » About... » INI file location)
bookmark.ini (Favorites)
XFlash.ini (Flash export add-on)
XPaint.ini (Paint add-on)
XPNGout.ini (PNGout export add-on)
iptc.def (IPTC Keywords)
category.db (Database for categories)
XnView.db (Database for thumbnails cache)
default.bar (Default toolbars)
foo.bar (Customized toolbars)
Stored in XnView.dbXnTriq wrote: I don't know in which database the ratings, color labels and tags are stored in. It's either category.db or XnView.db
