I use Version 1.97.6 with nef, xmp and jpg files. Now, when I move, copy or delete a nef file, the jpg will "go with" the nef but the xmp remains untouched.
Of course, I use Option/General/File op/For copy/move use companion.
Am I missing something?
Kind regards,
Thomas
.xmp companion not moved
marsh
Re: .xmp companion not moved
The following can be added manually to xnview.ini file:
[File]
Companion_00=nef:xmp
Companion_01=nef:jpg
Here is a post about designating companion files:
http://newsgroup.xnview.com/viewtopic.p ... 137#p56137
[File]
TD
Thank you very much, there was no "Companion_No" line in my xnview.ini but XnView treated the jpg like a companion of the nef anyway.marsh wrote:The following can be added manually to xnview.ini file:
[File]
Now I added only the first line of your suggestion and XnView behaves like I want it. It treats only the xmp file as a companion.
Thanks, problem solved!
