How do I create an Association to open a Slide Show that I saved to My Pictures?
Many thanks
Opening a slide show file
Re: Opening a slide show file
If you want to associate slide show files with XnView, you have to set the following option:
Menu "Tools->Options", category "Install", checkbox "Associate Slide File with XnView"
Hi helmut......that did the trick. I am impressed with the program and this forum.......I am going to register and become an active member.
Many thanks for your assistance.
<a href="http://www.gifs.net/animate/babynewyear.gif"><img src="http://members.lycos.co.uk/bejay1938/Xt ... 2.gif"></a>
paul_ahb
Is there any reason why this isn't done by default?helmut wrote:If you want to associate slide show files with XnView, you have to set the following option:
Paul
I prefer the user to make the association....paul_ahb wrote:Is there any reason why this isn't done by default?helmut wrote:If you want to associate slide show files with XnView, you have to set the following option:
