Convert multipage tiff recursive.
Mlearning
Post by Mlearning »
Good Morning.
I know that this topic was spoken and I check the information but I cannot finnish my script.
I have a massive scanner and I scanning a lot of simple tiff page documents. They are saving in a folder. The structure is:
FOLDER\101110\001
FOLDER\101110\002
FOLDER\DATETODAY\001
FOLDER\DATETODAY\00N
How you can check I have a lot of tiff in each folder number (001,002...)
I want to create a multi page tiff old each folder where are tiff files.
I've create a script
FOR /r /d %%a IN (*) DO nconvert.exe -multi -out tiff -o %%a %%a\*.tif
But this script creates white documents in ech datefolder with 1kbsize because are not tiff in the folder and I don't know what I should write in the script to only create tiffmultipage where it find tiff.
In addition I would like that the script creates the multipage tiff in other folder
Could you please give some help?
Thanks in advance.
DryLand404
Re: Convert multipage tiff recursive.
Post by DryLand404 »
Try
FOR /r /d %%a IN (*.tif) DO nconvert.exe -multi -out tiff -o %%a %%a\*.tif
