MP 0.32 add program... bug
macos
Post by macos »
exit~
macos
Re: MP 0.31 does not add program... bug
Post by macos »
1.MP 0.32 add program... selected more images ,alt + 1 only open single image?
2.MP 0.32 Can not drag the picture to another folder ,or copy to another folder ,in window
exit
I can't reproduce. Which OS?
macos wrote:1.MP 0.32 add program... selected more images ,alt + 1 only open single image?
You would like that 2 instances of program are started?
From thumbnails view?
macos
Post by macos »
Select multiple images, but can only be opened with a PS program
yes!
yes!
To a folder in thumbnail view?
macos
Post by macos »
xnview wrote:
yes!
Yes.
macos wrote:
xnview wrote: To a folder in thumbnail view?
Yes.
I have no problem to drag&drop a file into a folder in the the thumbnail view. Which OS?
macos
Re: MP 0.32 add program... bug
Post by macos »
drag&drop a file into a folder in the the thumbnail view,
os win7
macos wrote:drag&drop a file into a folder in the the thumbnail view,
os win7
Oh ok, in the FOLDER view. I must add it...
macos
Post by macos »
os win7
0.33 Or should not
macos
Post by macos »
1.9 MP0.33
