When I browse many folders, I enter the folder, scroll down and then I have to press Home and Enter and Right and Enter to go to next folder.
I suggest the "next subfolder" item in browser, as option, it would be the last item in folder, it should work the same as "go to the next subfolder (fullscreen)" option.
Example:
If the current folder would be the last subfolder in the folder, then "next subfolder" item should work as "go up", then the active, selected item should be the previous subfolder, or the [..] item.
Alternative option (I guess already requested) would be the "[..]" item as the last folder item, the same as the first [..] item.
Thanks.
"Next subfolder" item as the last item in browser
