v0.32: Thumbs only view
JohnFredC
Post by JohnFredC »
Pierre:
Thank you for adding a "Thumbs only" command.
It would be a great addition to the Browser except... it should toggle between the current layout and "thumbs only", without making any visible changes to the current layout..
Unfortunately, in the 0.32 version, executing "Thumbs only" twice resets the layout.
John
Re: v0.32: Thumbs only view
right
Markorki
Post by Markorki »
My XnView is in french...
What is the complete path to "thumbs only view" in french ?
Is it supposed to show only the thumbs panel and hide the 3 others ( favorites/folders/categories tabs, metadata tabs , preview ) ??
Dommage, l'était sympa cette planète ;-(
JohnFredC
Post by JohnFredC »
Currently (v 0.32) "Thumbs view only" is only available for the toolbar.
Go to Tools->Settings->Interface->Toolbar, select Browse Mode. "Thumbs view only" will be in the left list. Add it to the right list, click OK and you will have appended it to your toolbar. If you size the Settings dialog wider, you will find that the command name is: cmd_thumbsView.
There is no toolbar icon for it yet, though, and as stated above there is a small bug with its behavior.
John
JohnFredC
Post by JohnFredC »
Another thought:
"Thumbs only" mode should really be:
Hide Preview and Info but continue to show the Folder/Category/Favorites trees if they are already visible.
It is OK with me if hiding the Navigator group is an extra step.
John
Moderator & Librarian
Markorki wrote:What is the complete path to "thumbs only view" in french ?
As of beta 0.32, the string has not been translated yet:
Please check XnViewMP v0.33
JohnFredC
Post by JohnFredC »
v0.33 works much better! Thanks!
John
