Hello.
It is possible to change the names of the categories of "Rating" and "Color Label" ?
For example: The name "Excellent" in "Series 1 " or "work" in "size: 40x60 cm"
Best regards
Ftomasch
Modification of the terms
ftomasch
Re: Modification of the terms
I can see "xnview.ini" nothing appropriate
The concept of categories is perhaps twice.
I wanted to ask you if you could change the terms "Categories/Rating" or "Categories/Label" be change or hide.
In Categories / Categories I've inserted my terms.
Best regards
ftomasch
Best regards
ftomasch
you would like to change "Excellent/Good/Average/Below/Bad" to another label, right?
ftomasch
Yes, that´s exactly what I wanted to say!!
Best regards
ftomasch
Best regards
ftomasch
ftomasch
Thanks a lot.
Is there an overview about what you can change in xnview.ini?
Best regards
ftomasch
Best regards
ftomasch
