WMF EMF native support
DOS386
Post by DOS386 »
Old thread (2003 to 2006): http://newsgroup.xnview.com/viewtopic.php?t=184
http://xnview.com/en/formats.html
Windows & Aldus Metafile wmf (Unix : wmftogif required)
Windows Enhanced Metafile emf (Windows only)
Questions:
1. Does XN / NC / Pierre's lib have native code to support those formats (convert into some "standard" bitmap format) ?
2. If answer is NO (as I suspect), does such code / tool exist elsewhere ?
Re: WMF EMF native support
No, only on windows. And i don't know such tools. wmftogif is no more available...
DOS386
Post by DOS386 »
xnview wrote:No, only on windows. And i don't know such tools. wmftogif is no more available...
http://www.skynet.ie/~caolan/Packages/libwmf.html download works and has source code from 1999 ... about 480 KiB C and H in 23 files :shock:
