Use single-click to view image(s) / enter folder(s)
Dreamer
Post by Dreamer »
If we have "single/double-click" in the folder tree, maybe we could have "single/double-click" (on the thumbnail/file/folder) also in the browser...
[x] Use single-click to view image(s) / enter folder(s) / open item(s) (point to select)
(Update: point to select)
Update:
3-way option group (suggested by JohnFredC):
  • State 1: One-click files and folders
    State 2: One-click folders
    State 3: One-click off
marsh
Post by marsh »
This could prove very tricky to edit images. Then there is the problem of accidental clicks. I think windows is great at not having this for a default behaviour.
Dreamer
Post by Dreamer »
marsh wrote:This could prove very tricky to edit images. Then there is the problem of accidental clicks. I think windows is great at not having this for a default behaviour.
I want it only in the browser.
With the current double click you can copy or move files/dirs. by accident very easy too.
I hate also "1 click rename" feature, often I click on file by accident and I must click to another image, then back to first image and then double click...
I want "Use single-click to view images / enter folder" as option and disabled by default.
I second this. If you really want to introduce this, there must be an option. And not in 1.80, please, since this is likely to introduce many new bugs.
Yes not in 1.80
Dreamer
Post by Dreamer »
OK
Dreamer
Post by Dreamer »
It could be better with this, but maybe it should be added as separate option.
Navigation with this feature(s) would be faster/easier for some users (e.g. for me :wink: ), of course not for all...
There are already two similar options for folder tree - "Single click to expand folder tree" and "Auto collapse", so I think also this option would be useful for some users (not just for me).
herr_k.
Post by herr_k. »
yes would be indeed faster. i would use it. but only in the thumb-browser as quoted. as an option.
and i don´t click "accidently" somewhere .).
