Sir,
It's disappointing that "xn" has no option to enlarge pics in custom zoom and increase the zoom
percentage as desired.
raama -krushna from india
Custom zoom
Re: Custom zoom
• Options (F12) >> View >> Zoom step :
[Zoom method…] [Zoom step - percentage, type the wished one here]
Re: Custom zoom
But still,it reverts back to the default setting,even if it's changed.
krushna
krushna
Re: Custom zoom
• No problem here for a long while, these options are kept through the sessions. You might find in your <xnview.ini> file :
[View]
ZoomFStep=1 —> Fixed zoom step you typed (i.e. here 1%)
ZoomRStep=1.41 —> Relative zoom step …
ZoomStep=1 —> Zoom step (basic)
• If these values are not saved when you change the step, maybe you are not using the right <xnview.ini> file …
- Please check this in Options >> System Integration.
