One particular APNG is stuck at first frame
MaxSt
MaxSt
MaxSt
Re: One particular APNG is stuck at first frame
I copied zstream from first 2 frames into separate PNG files:
They both work just fine, that means there is no zstream data errors.
right, it's not the problem, but a problem with chunk & libpng...
MaxSt
Another example: 2 frames, also stuck at first frame:
DOS386
Still buggy in 1.99.1. Warns about multiple pages, but neither animation runs, nor I can see other frames as pages
