Please I want the software to Stop asking me if I want to overwrite a picture each tie i make a change and moveon to the next photo.
How do I stop this from happening?
Thank you,
Duets
Overwrite
marsh
Re: Overwrite
Hello, this is done by editing xnview.ini with notepad. The ini's location is shown in about dialog.
From Clean save dialog,
The current dialog behaviour is:
[Start]
ShowSaveDlg=
0 = Disable dialog for current session
129 = Disable dialog and automatically save changes when closing window.
130 = Disable dialog and do not automatically save changes.
I highly recommend 130
Duets
Re: Overwrite
Thank you Marsh for your quick reply.
But where do I find the xnview.ini
thank you,
Duets
thank you,
Duets
marsh
Re: Overwrite
From Info about XnView's settings (store & load),
Location of .ini files
The setting "Save options" (see above) also controls the location of the .ini file:
* User - User's Application directory
* Program - Program directory of XnView
* Windows - Windows directory
The full path of the .ini files is displayed in the About dialog (menu "Info > About...").
