Customized columns
con.aba
Customized columns
Post by con.aba »
When setting the "view as" option to: Details or Thumbnail & Details
there are limited columns that you can choose from in these types of view.
I think it could be more useful to give the ability to customize these columns, so the user can choose the columns that he needs.
For me, I have hundreds of pictures with one caption for each related group of pictures, and I need to add a column that shows the caption so I can sort them by the caption and make them into groups depending on there captions.
Many thanks...
Re: Customized columns
Currently only XnViewMP can have customized columns....
