Wrong HTML value in “Display Colour Info” with 32-bit icons
View » Display Colour Information...: There's an 8-digit value for HTML in the tooltip with 32-bit icons.
marsh
Re: Wrong HTML value in “Display Colour Info” with 32-bit ic
Post by marsh »
The fourth set: MP's batch convert change color depth transformation changes this info with alpha field. w/32bit png sample.
Doesn't match RGB label.
I don't understand, what is the problem??
xnview wrote:I don't understand, what is the problem??
Aren't HTML colors defined using a six-digit hexadecimal notation?
  • #RRGGBB
    #RRGGBBAA (?¿?)
    #AARRGGBB (Android, WPF/XAML)
    #AABBGGRR (KML)
    0xAARRGGBB (Java, Flash/ActionScript etc.)
————————————————————————————————————————————————>8
marsh
Post by marsh »
Seperating new information would be a quicker reference?
X: 0 Y: 0
RGB (0,0,0) 0 Alpha
HTML (#000000) 00
