[Fixed in RC7] Filmstrip & Thumbnail height slider
Locked
Lesmo16
Post by Lesmo16 »
Filmstrip layout is special, because it has no vertical ScrollBar.
Changing the thumbnail size in filmstrip layout with menu "View" -> "Thumbnail size" everything works fine. It doesn't matter if switching from small to big or vice versa, the hight of the filmstrip adapts to the height of the thumbnail - no vertical ScrollBar appears.
Changing the thumbnail size in filmstrip layout with the slider (height) in "Options" -> "Browser" -> "Thumbnail" the height of the filmstrip isn't adjusted correctly. When sliding to smaller a margin remains under the thumbnails, when sliding to bigger the vertical ScrollBar appears.
I think that should be easy to fix ... :wink:
Everyone who believes in telekinesis, raise my hand!
Re: [Bug:] Filmstrip & Thumbnail height slider
Lesmo16 wrote:Filmstrip layout is special, because it has no vertical ScrollBar.
Ok
Lesmo16
Post by Lesmo16 »
Ok
Still buggy in RC6 - same behaviour as in RC5.
The new height setting applies only after restart of xnView.
[edit]
It also applies if filmstrip height or folder tree width is minimally altered.
[/edit]
Dreamer
Post by Dreamer »
Moved back to "New/Open".
Lesmo16
Post by Lesmo16 »
Fixed!
Locked
