768 x 576 thumbnail is not showing in 768 x 576
Abdu
Post by Abdu »
I am having an issue with the larger size thumbnails. They are not showing in the chosen size. If I choose 768 x 576, the thumbnail is not 768 x 576. The width is 160. What seems to be the problem? Using 1.98.2 in Windows 7.
Re: 768 x 576 thumbnail is not showing in 768 x 576
Is Use huge thumbnails activated?
  • Tools » Options... » Browser » Thumbnails » Appearance » Appearance
Abdu
Post by Abdu »
Yes it is.
:? And what happens if you Rebuild thumbnails (View menu)?
Abdu
Post by Abdu »
Same result.
ckv
Post by ckv »
Do you have "Use Embedded thumbnail" enabled in the thumbnails options?
If yes, disable it or also select "Create thumbnail from original image if embedded is smaller than thumbnail size"
