Resize Thumbnail does not work in huge sizes
jsony
Post by jsony »
Hallo, I want to show the thumbnails in huge size, but I get only some small one. The pictures are jpg. Only in a few times I get bigger pictures.
How can I change the size if 384/288 does not work correct?
Many thanks.
Jürgen
Re: Resize Thumbnail does not work in huge sizes
ckv ([url=http://newsgroup.xnview.com/viewtopic.php?p=98021#p98021]768 x 576 thumbnail is not showing in 768 x 576[/url]) wrote:Do you have "Use Embedded thumbnail" enabled in the thumbnails options?
If yes, disable it or also select "Create thumbnail from original image if embedded is smaller than thumbnail size"
jsony
Post by jsony »
Many thanks,
that was a very good answer. I found it in the options and got now the bigger thumbnails.
Good luck and have a nice autumn.
Jürgen
Welcome to the forum, Jürgen :-)
