I'm using RC6 now, so I don't remember if this function was in previous versions or not...
Edit -> Copy image data
What does this do and how do I use it? I've tried everything I know and still can't figure out what it does.
Thanks.
What does "Copy image data" do?
Hmm, not sure whether "Copy image" would be clearer. What I would find perhaps clearer is "Paste image data" instead of "Import clipboard". But I'm not so sure with this one, either.Olivier_G wrote:I also find "Copy image data" misleading. I would prefer "Copy image" (in opposition to "Copy item/file").
At the moment, when copying the filename (as string) and the file is put into the clipboard. For all I know you can put only one item per type into the clipboard, so the clipboard is full, already.Olivier_G wrote:Even better: wouldn't it be possible to copy both to the clipboard so that what is needed in the output application can automatically be used?
