RC6: HTML Template: Loop command
<Moderator's note: This topic was split from topic "Create Webpage: Possible improvements">
- Loop Directions without HTML
Currently, #THUMB_START# and #THUMB_END# are used for looping over the thumbnails, which is good and clear. But these directions also generate a <tr> and a </tr>, I think this shouldn't be done since this limits down the usage.
For example, you cannot have a table one column of thumbnails using:
<table>
#THUMB_START#
<tr>
<td>
<a href="#FRAME_PAGE#" target="frame2"><img src="#THUMB_LINK#" border="0" alt="#FILENAME#"></a>
<div>#FILENAME#</div>
</td>
</tr>
#THUMB_END#
</table>
This should be implemented in 1.80, since a later change would affect all existing WebTemplates and users' WebTemplates.
The problem can be seen here:
Currently, the template is:
<br><br><center><table border="0">
#THUMB_START#
<td align="center" valign="bottom">
<a href="#FRAME_PAGE#" target="frame2"><img src="#THUMB_LINK#" border="0" alt="#FILENAME#" width="#THUMB_WIDTH#" height="#THUMB_HEIGHT#"></a>
</td>
#THUMB_END#
</table></center><br>
The result is:
<tr><td align="center" valign="bottom">
<a href="original/collage.html" target="frame2"><img src="thumb/t_collage.gif" border="0" alt="collage.jpg" width="96" height="100"></a>
<div>collage.jpg</div>
</td>
<a href="original/collage1.html" target="frame2"><img
As you can see, a <tr> and </tr> is inserted, which shouldn't be there.
XnView 1.80 <x>
Looking at the Webpage create for a second time I've found that there's a setting 'Columns', which controls how '<tr>' are set.
I wonder whether the page template should control the <tr>, only, and no control "Columns" would be needed. At the moment, a webtemplate with all thumbnails aligned in one row is not possible.
Have to think about this...
helmut wrote:Looking at the Webpage create for a second time I've found that there's a setting 'Columns', which controls how '<tr>' are set.
Perhaps i can add #THUMB2_START#, #THUMB2_END# which not create <tr></tr>??
Yes, that's a good idea. THUMB2_START sounds a bit strange, though, but I can't think of anything better at the moment.
Is THUMB2_START available in the current XnView version 1.94?
EDIT:
Just tried and from what I can see THUMB2_START / THUMB2_END do work.
A list of all HTML keywords available can be found in topic Webpage templates: List of keywords.
