Xnview integration on Total Commander it's great but Gamma correction doesn't work when using quick view mode (Ctrl-Q) or thumbnails on Tc. Thanks
1.81? RC6: Gamma & TC
Re: RC6: Gamma & TC
This means serving to TC according to the state of Options -> View -> Use gamma correction.Anonymous wrote:
Xnview integration on Total Commander it's great but Gamma correction doesn't work when using quick view mode (Ctrl-Q) or thumbnails on Tc. Thanks.
I support it, if it isn't too much work for 1.80 final release.
Otherwise it should be postponed, IMO.
Everyone who believes in telekinesis, raise my hand!
Re: RC6: Gamma & TC
Please not in 1.80Lesmo16 wrote:This means serving to TC according to the state of Options -> View -> Use gamma correction.Anonymous wrote:
