I do not know if you consider this as a bug in Xnview, but i feel it is.
when i view a image In fullscreen mode with image size set to "no fit"(select a large image), scroll down to bottom and now navigate to
the next image ; the next image does not start the display from top.
i mean the next image screen position will be the same as last view position of previous image.
the next image should ideally start from the top and left.
if this cannot be default , then at least provide an option for it.
Fullscreen navigation to next image
Re: Fullscreen navigation to next image
pls ignore ; did not see the option before
found the option.
select "reset X/Y' in view.
found the option.
