When viewing a complete (AVI) movie in (lite) fullscreen, ESC key will not close it. The same with menu item "Close" in context menu. (Bug1). Also, Zooming to screen size does not work using '/' key. (Bug2).
When closing the fullscreen using "Fullscreen F11" (btw, for what is this menu entry, there is 'Close' (Bug3?)), the movie closes. But you cannot open and view the movie, again. (Bug4).
XnView 1.80 <x>
RC6: Problems with movie in fullscreen (lite)
Olive
Dreamer
Re: RC6: Problems with movie in fullscreen (lite)
I can confirm bugs #1, #2, #4 but only when I use controls (play/stop/mute/volume...), not when viewing a complete movie.helmut wrote:When viewing a complete (AVI) movie in (lite) fullscreen, ESC key will not close it. The same with menu item "Close" in context menu. (Bug1). Also, Zooming to screen size does not work using '/' key. (Bug2).
Close in context menu (FS lite) doesn't work completely in Viewer (with movies only).
F11 key doesn't work in Viewer when I switch to the next file (with audio files - mp3 - only).
I don't think, bug #3 is a bug, there is "Fullscreen" and "Close" also in (almost) all context menus, so it should be here too.
Dreamer
Dreamer
