1.98.7, can't set File Association
Attacker
Post by Attacker »
Windows 7 x64 SP1
XnView Full 1.98.7
A newly installed Windows 7
I found it failed to set XnXiew to associate with image files such as jpeg, bmp, gif
Re: 1.98.7, can't set File Association
You need to start XnView with admin rights to be able to change associations
Attacker
Post by Attacker »
xnview wrote:You need to start XnView with admin rights to be able to change associations
Of course I did it
but it didn't work as the earlier version
The following is JPEG's file association in Registry, as an example
after I run XnView in Admin rights and set file associations
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\jpegfile]
@="JPEG Image"
"EditFlags"=dword:00010000
"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\
00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\
32,00,5c,00,73,00,68,00,65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,\
00,2c,00,2d,00,33,00,30,00,35,00,39,00,36,00,00,00
"ImageOptionFlags"=dword:00000001
[HKEY_CLASSES_ROOT\jpegfile\CLSID]
@="{25336920-03F9-11cf-8FD0-00AA00686F13}"
[HKEY_CLASSES_ROOT\jpegfile\DefaultIcon]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,69,00,6d,00,\
61,00,67,00,65,00,72,00,65,00,73,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,37,\
00,32,00,00,00
[HKEY_CLASSES_ROOT\jpegfile\shell]
[HKEY_CLASSES_ROOT\jpegfile\shell\open]
"MuiVerb"=hex(2):40,00,25,00,50,00,72,00,6f,00,67,00,72,00,61,00,6d,00,46,00,\
69,00,6c,00,65,00,73,00,25,00,5c,00,57,00,69,00,6e,00,64,00,6f,00,77,00,73,\
00,20,00,50,00,68,00,6f,00,74,00,6f,00,20,00,56,00,69,00,65,00,77,00,65,00,\
72,00,5c,00,70,00,68,00,6f,00,74,00,6f,00,76,00,69,00,65,00,77,00,65,00,72,\
00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,30,00,34,00,33,00,00,00
[HKEY_CLASSES_ROOT\jpegfile\shell\open\command]
00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,72,00,75,00,\
6e,00,64,00,6c,00,6c,00,33,00,32,00,2e,00,65,00,78,00,65,00,20,00,22,00,25,\
00,50,00,72,00,6f,00,67,00,72,00,61,00,6d,00,46,00,69,00,6c,00,65,00,73,00,\
25,00,5c,00,57,00,69,00,6e,00,64,00,6f,00,77,00,73,00,20,00,50,00,68,00,6f,\
00,74,00,6f,00,20,00,56,00,69,00,65,00,77,00,65,00,72,00,5c,00,50,00,68,00,\
6f,00,74,00,6f,00,56,00,69,00,65,00,77,00,65,00,72,00,2e,00,64,00,6c,00,6c,\
00,22,00,2c,00,20,00,49,00,6d,00,61,00,67,00,65,00,56,00,69,00,65,00,77,00,\
5f,00,46,00,75,00,6c,00,6c,00,73,00,63,00,72,00,65,00,65,00,6e,00,20,00,25,\
00,31,00,00,00
[HKEY_CLASSES_ROOT\jpegfile\shell\open\DropTarget]
"Clsid"="{FFE2A43C-56B9-4bf5-9A79-CC6D4285608A}"
[HKEY_CLASSES_ROOT\jpegfile\shell\printto]
[HKEY_CLASSES_ROOT\jpegfile\shell\printto\command]
@=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,72,00,\
75,00,6e,00,64,00,6c,00,6c,00,33,00,32,00,2e,00,65,00,78,00,65,00,22,00,20,\
00,22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,\
25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,\
00,69,00,6d,00,67,00,76,00,77,00,2e,00,64,00,6c,00,6c,00,22,00,2c,00,49,00,\
6d,00,61,00,67,00,65,00,56,00,69,00,65,00,77,00,5f,00,50,00,72,00,69,00,6e,\
00,74,00,54,00,6f,00,20,00,2f,00,70,00,74,00,20,00,22,00,25,00,31,00,22,00,\
20,00,22,00,25,00,32,00,22,00,20,00,22,00,25,00,33,00,22,00,20,00,22,00,25,\
00,34,00,22,00,00,00
Attacker wrote: but it didn't work as the earlier version
Which version do you had? 1.98.5?
Attacker
Post by Attacker »
Every version, including 1.98.5
I have used XnView for several years
and I always use the latest version
and they all seem OK in file association
Ok, a new bug related to this fix
Attacker
Post by Attacker »
xnview wrote:Ok, a new bug related to this fix
Thank you
Hope the new version comes soon
I've sent you a PM
Attacker
Post by Attacker »
xnview wrote:I've sent you a PM
Yes
It works nice
