Animated gif and Slide show
DRunco
Post by DRunco »
when I'm displaying a slide show of animated gifs, the transition use a timer (i.e. every five seconds, picture will change, even if all frames were not displayed/even if the animation has to loop for a few frames).
I'm suggesting to add an option (i'm thinking with a tick in Option->View->Misc.->[Quick Slide Show]) that allows the program to check if there's multiple frames in a picture, and in that case override the timer to change the picture at the end of the animation/after displaying all frames.
