DPX writing trouble
cpinla
DPX writing trouble
Post by cpinla »
I have been reading old posts about Nconvert converting 10bit dpx to 8 bit when the files are read. However, I have not been able to figure out what combination of arguments I need in order to save out a 10bit dpx. I am aware that XnView can in fact do this as I have been able save out the 10 bit dpx and it works great (using the additional DPX write options), but unfortunately those settings don't get exported when I use the export button from the Batch Processing window.
Any help would be greatly appreciated.
Thanks
Chris
Re: DPX writing trouble
With Nconvert you must use a lut to convert 8=>10 bits (-ilut)
You have 2 lut in XnView package
cpinla
Post by cpinla »
Is there a way to use the 8 to 10bit lut but not have it affect the color information to the image? I essentially just want a 1 to 1 copy of my dpx image with text applied over the top, however if I use the ilut and olut features it shifts the color information of my image.
Using or not lut, it's the same...
